Date/Time: Sun, 19 Jan 2025 03:28:17 +0000
Single vs dual processor
View Count: 1176
[2018-03-14 17:43:38]
LucentTrader - Posts: 35
I am building a new trading system. The choice of processors is Intel i9 vs Xeon. With the Xeon I can get between 10 and 20 cores and significantly more memory space and cache. I can also have a dual processor. Can Sierra Chart take advantage of a dual processor system and use available cores as system load increases?
[2018-03-14 18:27:30]
Sierra Chart does use multiple threads. But to more fully take advantage of multiple cores you need to use multiple instances. Refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Date Time Of Last Edit: 2018-03-14 18:27:45
