Date/Time: Sun, 19 Jan 2025 03:27:53 +0000
Extend Bar Value Until Further Intersection on Intraday Chart?
View Count: 639
[2018-03-14 16:55:38] |
jsoviero - Posts: 84 |
I am not able to load this study onto an Intraday Chart. It loads fine on a Historical Chart, however there are no plots on an Intraday Chart. The existing documentation does not provide any beneficial instructions. Please advise how to have this study plot on an Intraday Chart. Thanks in advance for any reply. |
[2018-03-14 18:05:44] |
We do not think it is practical to use on an Intraday chart which shows the full 24 hours of data. The result you see is valid. Very simply because the open high low close values of a bar are going to in almost all cases be intersected at the very next bar.
