Date/Time: Sun, 19 Jan 2025 03:38:27 +0000
Problem with Session Indicator
View Count: 1008
[2018-03-14 16:35:23] |
Rrrracer - Posts: 20 |
Hey guys, have a little problem with the Session Indicator. Not sure what happened, but previously it would always show at the very bottom of a chart. Now it stays at the lowest price bar on the chart, with a gap between it and the bottom. It's been like this for a few weeks IIRC. It happens on all charts on the screen. Thanks. http://www.sierrachart.com/image.php?Image=1521045176533.png |
[2018-03-14 18:04:30] |
That looks normal to us. Select Chart >> Reset Scales. We cannot provide further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-15 00:01:33] |
Tried resetting the scales, changing all scale settings, resetting default indicator settings, loading an older 32 bit version of SC... to no avail. Very well, just so you know something has changed. I've tried every setting I can find. It is not displaying the way it was previously. Previously the Session Indicator was docked at the bottom of the chart, not at the bottom of the lowest bar on the chart. Apologies, not trying to be argumentative, but it makes no sense for it to be displayed this way. http://www.sierrachart.com/image.php?Image=152107192991.png |
[2018-03-15 20:57:23] |
An update. I had a trading buddy load the study on his charts and it is docked at the bottom as it should be, so apparently the problem has something to do with my own particular installation or a setting gone awry somewhere. I'll continue looking.
[2018-03-15 21:20:53] |
Did Chart >> Reset Scales remove the space above and below the chart bars? We would expect that to be the case. What is the Scale Range for the main price graph set to? With the way that study is designed, it is going to be aligned to the lowest chart bar. It is a study which has a scale. And it is going to be affected by Interactive Scale Range and Move. Although we see that would not be the case when using a Constant Range Scale Scale Range for the for the main price graph. Nothing has changed at all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-15 21:21:28
