Date/Time: Sun, 24 Nov 2024 05:32:42 +0000
[User Discussion] - Aspect Ratio for Charts
View Count: 2160
[2013-10-01 23:09:45]
User24187 - Posts: 54
I would like to set my Chart Aspect Ratio 1:1.5
How would I do this?
Thanks.
[2013-10-02 03:04:13]
Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ConstantRelationship
[2013-10-02 20:04:56]
I am not able to figure out how to set a fixed aspect ratio of 1:1.5 for the horizontal and vertical axis. Please advise?
Date Time Of Last Edit: 2013-10-02 20:06:12
[2013-10-03 17:50:39]
You need to use X & Y Constant Relationship Scaling. And adjust the number of Bars and Value Range order to get this ratio. Here is the documentation:
Date Time Of Last Edit: 2013-10-03 17:50:54
[2013-10-03 17:50:53]
Bump really need help with this...
[2013-10-03 20:19:22]
mkata - Posts: 103
When setting the X & Y values, think of the Y(Values Range) as without a decimal point, then divide that number by 1.5, this will be your X(number of Bars), leaving you with a ratio of 1:1.5.
Don't remove the decimal, just think of it as missing in order to perform the calculation.
[2013-10-03 23:54:06]
Thank you
