Date/Time: Sun, 19 Jan 2025 03:21:04 +0000
import drawing from one chart to another
View Count: 690
[2018-03-14 12:22:11] |
User807026 - Posts: 86 |
Is there any way to import a drawing from one chart to another?
[2018-03-14 18:33:03] |
The only option is documented at the following link: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
