Date/Time: Sun, 19 Jan 2025 03:29:33 +0000
A FEW QUESTIONS
View Count: 875
[2018-03-14 03:23:47] |
User342238 - Posts: 44 |
Hi, a few questions here... 1. I am using SC for trading on Bitmex. After updating sc from the help menu, I find myself currently running 17125-32 bit. Am I using the right version or should I be using a 64 bit program? 2. And second question, is there a way to attach a stop to a chart indicator? I want to place a stop behind a basic moving average on the chart. Is there an easy way to do this as there is in ninjatrader? Thanks |
[2018-03-14 07:40:59] |
1. You are running version 1715. You can use either 32 or 64 bit, it does not matter. You should be running the current version and to update follow the instructions here: Software Download: Fast Update 2. Refer to: Attached Orders: Study Controlled Targets and Stops Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-14 07:41:45
[2018-03-14 15:47:28] |
Hi, Regarding q1, how does one choose between 32 and 64? When I use the help menu update link it just downloads and installs 32bit automatically. 32 bit seems to work fine but I do have some lag loading some charts and if there is a performance improvement with 64 I'd rather use it, but it sounds like 32 is more stable, is my assessment correct? |
[2018-03-14 18:02:04] |
Refer to: Software Download: Difference Between 32 and 64-bit Versions Also, refer to help topic 30: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-14 18:03:27
