Date/Time: Sun, 19 Jan 2025 00:03:39 +0000
copy SierraChart folder to new HD
View Count: 771
[2018-03-13 21:18:19] |
User845611 - Posts: 13 |
Was running SC on #1comp when it went bellyup. Now I have SC on #2 comp. I put HD #1 in a dock and was going to ask what files to copy in #2 when I decided to ask if I can shoot the moon. Please tell me you think I can just copy the SC folder or am I dreaming. Something tells me it will not work but I am a comp dummy.thanks for your assist
[2018-03-13 21:24:09] |
User701453 - Posts: 176 |
Did a search using the search feature and this was first result returned: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System |
[2018-03-14 00:12:42] |
Yes the link given in post #2 is what you need to do.
