Date/Time: Sat, 18 Jan 2025 23:57:21 +0000
How to Permanently Center the DOM Bid/Ask Point?
View Count: 1081
[2018-03-13 16:53:16] |
gayer2428 - Posts: 89 |
I am constantly Re-centering the DOM and end up hitting the Buy/Sell buttons by mistake. How can the DOM be centered at the Bid/Ask point, on a constant basis ? Thanks. |
[2018-03-13 19:17:25] |
Refer to Constant Range Scale Mode: Chart Scale and Scale Adjusting: Constant Range (Scale Range) You can center based on the last trade price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
