Date/Time: Sun, 19 Jan 2025 00:04:54 +0000
Aligned Flex Renko
View Count: 1105
[2018-03-13 16:27:01] |
ZenAlchemist_OLD - Posts: 1 |
How would I align a Flex Renko chart the way an Aligned Renko is? I am looking for alignment, but also to specify the trend offset. Thanks |
[2018-03-13 19:14:17] |
This is not supported.
