Date/Time: Sun, 19 Jan 2025 00:01:33 +0000
custom bar period 3 minutes toolbar command
View Count: 764
[2018-03-13 16:13:51]
User59217 - Posts: 13
Is is possible to create a custom bar period 3 minutes toolbar command?
[2018-03-13 17:07:28]
User701453 - Posts: 176
Yes, I have quite a few custom bar periods.
You can even do it with Tick, Volume, Renko, etc
Its easy to do.
This should guide you thru your quest:
Control Bar: Custom Buttons for Intraday Chart Bar Period
This is Sierra Charts Documentation page:
Table of Contents | (Settings Windows)
Date Time Of Last Edit: 2018-03-13 17:12:04
[2018-03-13 17:12:02]
Thanks for the info. That was very helpful.
