Date/Time: Sat, 18 Jan 2025 23:58:52 +0000
[Locked] - Tools>>>Draw Volume Profile
View Count: 1243
[2018-03-13 15:51:25]
User884307 - Posts: 173
when in a particular (or any) chart, selecting the tools>draw vol profile and applying it to the chart, is there anyway to turn off the "snap" to the high and low of the selection.
For example, if selecting the VbP over 2 bars, instead of study snapping 9by default) to low price of the left bar and the high of the adjacent right bar, you can adjust so that VbP starts (for example) midway point of the left (start) bar and maybe 2 ticks (for example) off the high of the bar to the right ....... i hope you get the gist of what Im saying.
Cheers in advance
[2018-03-13 19:13:35]
Uncheck the option under Tools >> Auto Snap on Creation.
[2018-03-13 19:25:12]
hi, thanks for replying
I've done that, not sure really what difference It has done, the Volume by Price still "snaps" to the high/low of the bar hence displaying VbP for the high/low "snap", instead of the VbP for the points (price levels) I clicked.
Cheers
[2018-03-13 19:28:23]
Now that we pay closer attention to this, this is totally unsupported. And never will be. This thread is locked.
