Date/Time: Sun, 19 Jan 2025 03:29:17 +0000
[User Discussion] - Reload and recalculate every thirty seconds.
View Count: 1315
[2018-03-13 15:05:32] |
User114886 - Posts: 4 |
Hi, I checked the support board for my inquiry and the only good answer I saw was to code in ACSIL. I was wondering if you had a simpler solution to my problem wich is to reload and recalculate automatically every X seconds instead of doing it manually.
[2018-03-13 16:55:11] |
Sawtooth - Posts: 4155 |
Kiwi created a Recalc study: request for a very simple ACSIL study but you'll need to make these changes and recompile: Kiwi Resync Study - Memory leak? |
