Date/Time: Sun, 19 Jan 2025 03:19:51 +0000
Capture"Auto Trading Enabled-Chart" status
View Count: 1190
[2018-03-13 14:40:34] |
User701453 - Posts: 176 |
Is there a way to capture the "Auto Trading Enabled-Chart" status value. I need to be able to capture the On/Off value so I can display it on the chart itself. I have a chart book containing 5 different markets and I need to know at a glance which chart has "Auto Trading Enabled-Chart" mode enabled. I would like to display the value in a Text Display study. |
[2018-03-14 01:22:59] |
Since there appears to be no current way to capture the chart enabled status with current studies. I writing my own DLL. The dll compiles without any errors but Im only getting 0.00 from sc.ChartTradeModeEnabled. Even when I have the "Auto Enabled - Chart" checked. I need to know the type and format of value returned from sc.ChartTradeModeEnabled. I`m currently using DRAWSTYLE_TEXT. |
[2018-03-14 03:18:36] |
User553714 - Posts: 184 |
Is this what you're looking for? ACSIL Interface Members - Variables and Arrays: sc.IsAutoTradingEnabled |
[2018-03-14 05:28:04] |
Yes,Thanks. That link helped me to locate the sc function for the "Auto Enabled - Global" option I was going to look for next. Currently, This is the block of code that I am using to determine Auto trade Status. However, it only returns 0.00 for each option. Even when I have both Auto Trade options checked under the Trade tool bar. if (sc.IsAutoTradingEnabled) { //GlobalTradeEnabled[sc.Index] = "Enabled";//make it more logical GlobalTradeEnabled[sc.Index] = sc.IsAutoTradingEnabled; } else { //GlobalTradeEnabled[sc.Index] = "Disabled";//make it more logical GlobalTradeEnabled[sc.Index] = sc.IsAutoTradingEnabled; } if (sc.ChartTradeModeEnabled) { //ChartTradeEnabled[sc.Index]= "Enabled";//make it more logical ChartTradeEnabled[sc.Index]= sc.ChartTradeModeEnabled; } else { //ChartTradeEnabled[sc.Index] = "Disabled";//make it more logical ChartTradeEnabled[sc.Index] = sc.ChartTradeModeEnabled; } |
[2018-03-14 05:50:42] |
As far as I can tell the function GlobalTradeEnabled does not exist. If you are just trying to determine whether AutoTrading is on off then you just do something like if (sc.IsAutoTradingEnabled == 1) --> AutoTrading is enabled else --- > AutoTrading is Not enabled The correct function for determining Chart trading status is here ACSIL Interface Members - Variables and Arrays: sc.ChartTradeModeEnabled |
[2018-03-14 06:37:07] |
Thanks for your input and help. I`m using what may seem like a long code block, that could be made smaller. But I plan to add additional code within the decision statements. Such as write to message log, etc. Yes, Perhaps Sierra needs to update their support page. SC version 1705 allows you to choose To have a master switch "Auto Enabled - Global" for the entire Instance and then "Auto Trading Enabled-Chart" for each individual chart in the chart book. I was able to get the sc.IsAutoTradingEnabled status working. It returns a "1" now when it is enabled and a "0" when disabled. But only if "Auto Trading Enabled-Chart" is also checked for the chosen chart. The sc.IsChartTradeModeOn also finally returns a value of "1". Bad part is that it stays a "1" even if the "Auto Trading Enabled-Chart" isn't checked. So looks like there is a internal platform bug. So long story is, I'm still not able to see at a glance when a chosen chart has "Auto Trading Enabled-Chart" checked. Perhaps SC support will take time to view this thread and provide a workable solution for the sc.IsChartTradeModeOn only returning a "1". Current code block below: if (sc.IsAutoTradingEnabled) { //GlobalTradeEnabled[sc.Index] = "Enabled";//make it more logical GlobalTradeEnabled[sc.Index] = sc.IsAutoTradingEnabled; } else { //GlobalTradeEnabled[sc.Index] = "Disabled";//make it more logical GlobalTradeEnabled[sc.Index] = sc.IsAutoTradingEnabled; } if (sc.IsChartTradeModeOn) { //ChartTradeEnabled[sc.Index]= "Enabled";//make it more logical ChartTradeEnabled[sc.Index]= sc.IsChartTradeModeOn; } else { //ChartTradeEnabled[sc.Index] = "Disabled";//make it more logical ChartTradeEnabled[sc.Index] = sc.IsChartTradeModeOn; } |
[2018-03-14 15:29:36] |
Ok, did more digging and sc.IsChartTradeModeOn and sc.ChartTradeModeEnabled both relates to the ability to trade from the charts. Unchecking those options, made sc.IsChartTradeModeOn go to "0" So, neither one of those is what I need. I need the sc function related to "Auto Trading Enabled-Chart". Looks like Sierra Support is ignoring this support request and the post has been set to "User Discussion", which I did not do. |
[2018-03-16 00:47:57] |
We will add this.
[2018-03-19 00:51:49] |
We will add this.
Any time frame on this addition?? |
