Date/Time: Sat, 18 Jan 2025 23:59:02 +0000
Help spread
View Count: 578
[2018-03-13 13:10:05] |
User774114 - Posts: 18 |
Hi I have account with AMP, with CQG data feed and sierra chart pakage 2 I like to see spread and trade , like Sp500 Vs NQ. I saw inside the simbols list but I dont get. I read I need to have sc Exchange data from SC. How I need to do ? Need change pakage ? My trades still with AMP ?? what exhange Non pro need to add ? thanks you. |
[2018-03-13 19:10:49] |
If that particular spread is not an exchange traded spread, then it cannot be traded. You can chart it by using this study: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
