Date/Time: Sun, 19 Jan 2025 00:12:08 +0000
SierraChart Candles vs Brokers are Different
View Count: 677
[2018-03-13 08:50:12] |
User371906 - Posts: 141 |
Hello, My brokers charts are set differently than my SierraChart (example EUSTX50), how can I set the chart (time, opening and closing hours, etc) to look the same? Candles are completely different on both. Broker is set: (Eastern European Time (EET) 24:00 Sun - 22:59 Fri (except 22:59 - 23:59 daily) Tried making several changes but none adjust. Attached My MT4 broker chart and below SierraChart http://www.sierrachart.com/image.php?Image=1520929748525.png Thanks |
EUSTX50 Not Sierra Chart.JPG / V - Attached On 2018-03-13 08:39:26 UTC - Size: 110.78 KB - 262 views |
[2018-03-13 19:21:09] |
We can only refer you to the Session Times documentation here: Chart Session Times As long as those Session Times are set correctly and as required, then the result is correct. Whether it matches the equivalent symbol from another service is not anything we can help with and is outside the scope of our support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-13 19:21:32
