Date/Time: Sun, 19 Jan 2025 00:23:41 +0000
User Question
View Count: 682
[2018-03-13 03:45:34] |
Sierra Chart - Max - Posts: 5779 |
> I signed up for my free BAR CHART real time data. How do I get it to start running on sierra chart and or how do i check and see what server my data is coming in from. > > Also at the top left of my sierra chart.. waht is DF, ST, BR and what do these numbers represent. > thank you > JAY > > p.s. if you have time can you explain trade routing thru sierra.. > > I am with s5 trader.. > > mkt order for example. > > 1. place mkt order though sierra chart DOM > > 2. does it go to s5 trading then to gain capital (FCM) then from gain to cme and back? > > or does it go directly to gain then cme or straight to cme? > > how does this work with a gtc stop or limit order? Sierra Chart Support |
[2018-03-13 04:41:38] |
1. In regards to the Sierra Chart Exchange Data Feed, assuming that is what you are referring to when you say Barchart real-time data, you just need to follow through the step-by-step instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions 2. Refer to: Status Bar 3. All order routing is to the FCM in this case Gain capital and then onto the exchange. This is going to be the same for Market, stop and Limit orders. More information: Order Types For further help you need to post on this Support Board so we can properly track this request. Otherwise, we do not know what your Sierra Chart account is and we have no context to help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-13 04:42:18
