Date/Time: Sun, 19 Jan 2025 00:13:14 +0000
Format function crashes SC
View Count: 649
[2018-03-13 02:02:07]
User44130 - Posts: 23
Using the below piece of code causes SC to shutdown (accidentally omitting "f" or other format letter after "%") as a result of buffer overflow. Couldn't locate this error for a long time as it's hidden from compiler in SC proprietary function. First time see this type of fault causing SC to close. Building error handling code for this function might be a good idea as it is must be used pretty frequently.
SCString MsgLog;
MsgLog.Format("Max Size Limit! CurrBSAv: % BSAvLmt: %f BSMax: %d ", CurrBSAv, BSAvLmt, BSMax);
sc.AddMessageToLog(MsgLog,0);
[2018-03-13 03:26:51]
This function unless used properly really can cause problems. There is no practical solution from our side. You must use it safely.
Date Time Of Last Edit: 2018-03-13 03:33:00
