Date/Time: Sun, 19 Jan 2025 00:10:51 +0000
Session Times Change on Symbol Rollover
View Count: 645
[2018-03-12 22:50:05]
Deucalion - Posts: 31
all of a sudden with Release 1705, I cant get my charts right after the new contracts for ES an NQ rolled over, smae thing happening with CL.......What I doing wrong....The white chart is from Ninja Trade 60M ES, same on Sieraa is wrong.....Ninja is, as usual , correct. Sierra is not...again!
Date Time Of Last Edit: 2018-03-13 00:20:57
imageright.png / V - Attached On 2018-03-12 22:49:06 UTC - Size: 65.13 KB - 247 views
imagewrong.png / V - Attached On 2018-03-12 22:49:12 UTC - Size: 49.82 KB - 233 views
[2018-03-13 00:19:34]
What you are describing is a case where the Session Times have changed on a symbol change according to the Global Symbol Settings.
Here is the documentation about preventing this:
Global Symbol Settings: Setting of Intraday Chart Session Times
And refer to:
Chart Session Times
But you should just set the Session Times you want in the Global Symbol Settings, so that this would not be a problem to begin with.
Also this has nothing to do whatsoever with Sierra Chart releases. It is totally unrelated.
Date Time Of Last Edit: 2018-03-13 00:20:39
