Date/Time: Sun, 19 Jan 2025 00:14:42 +0000
Pivot Points Daily issue
View Count: 629
[2018-03-12 15:40:25] |
User300798 - Posts: 23 |
I'm using daily pivot points indicator but the monday pivots are not calculating accurately. When the pivots are set to not use a daily chartbook the pivots calculate using the sunday evening data (I've checked this using the calculation). In the Pivot Points documentation the notes state that weekend data are ignored but that doesn't seem to be the case here. When I set the pivots to use a historical daily chart (in the same chartbook)the pivots calculate based on the current day rather than the previous closed day. I tried deleting and downloading the data again but this didn't solcve the problem. Any help would be greatly appreciated. Thanks. |
[2018-03-12 18:41:31] |
What is the exact name of the study you are using. What are the Session Times in the chart set to? Refer to: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php And what is the the time zone you have Sierra Chart set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-12 18:49:06
[2018-03-12 20:51:54] |
Thanks SC, I had 'use evening session' checked in chart settings. Unchecking this has solved the problem. Thanks again.
