Date/Time: Sat, 18 Jan 2025 23:55:45 +0000
Sierra Freezing
View Count: 603
[2018-03-12 15:14:03] |
User642139 - Posts: 20 |
Hello, Whenever I attempt to enter Trade > Chart Trade settings or Trade > Customize Chart/Trade DOM columns my sierra program just freezes. I then have to enter task manager to force exit sierra. I just updated to version 1716 and the problem remains. I am also running two instances, not sure if that is important. |
[2018-03-12 18:53:52] |
This is an operating system issue. Refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#DialogWindowsDoNotDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
