Date/Time: Sun, 24 Nov 2024 06:21:29 +0000
[User Discussion] - Cum delta Bars with 50 lot filter not calculating correctly.
View Count: 1385
[2013-10-01 18:11:03]
User32172 - Posts: 1
I have a chart of the ES Dec contract. I added to this chart a CUmulative Delta Volume Study. This study resets ever day and works great.
I would also like to have a study that shows what the bigger players who trade 50+ lots are doing. My friend has this study on another software package so I know approximately what the total for the day should be.
I went to chart settings<advanced settings 2 and set the VOLUME FILTER, EXCLUDE<=49. The number I get in my chart should be substantially less than my unfiltered volume chart since most trades are done using less than 50 lots. i am not getting this result. I get basically the same output.
Am I misunderstanding the filter or do I possibly have some settings incorrect?
Thx
[2013-10-02 03:02:25]
You will never figure this out. This is technically not possible. Anyone who tells you can make a determination of this, does not understand how the markets work.
We tested the volume filtering. It works fine and there is absolutely no reason why would there would be a problem with this. You must not have set it on the chart you have the Cumulative Delta Bars -Volume study on.
Date Time Of Last Edit: 2013-10-02 03:03:32
