Date/Time: Sun, 19 Jan 2025 03:25:43 +0000
CL Chart settings for Pivot Points
View Count: 1828
[2018-03-12 08:59:32]
Oliver Anderson - Posts: 3
Hello
i am trading in London and wish to apply pivot points to Cl charts.
i am confused as to which session hours and settings i need to get correct pivots on my CL charts.
please advise. screen shots of correct settings would be greatly appreciated.
Many thanks
[2018-03-14 18:49:21]
The official trading hours from the CME website is the following:
Sunday - Friday 6:00 p.m. - 5:00 p.m. Eastern US time.
Here are the instructions to set Session Times:
Chart Session Times
Here are the instructions to set the time zone:
Time Zone Setting
We are going to set these up as default.
Also your Sierra Chart account is expired.
Follow these instructions to add usage time to your Sierra Chart account:
1. Select "Help >> Add Usage Credit" on the Sierra Chart software menu.
You can also go to this page in your browser:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
Login with your Sierra Chart Account Name and Password.
2. Choose the particular Service Package that you want to automatically renew and press the "Update" button.
3. Add sufficient credit to your Services Balance using any of the available payment options:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
For further information, refer to:
Sierra Chart Purchase and License Information: Renewing Access
Date Time Of Last Edit: 2018-03-14 18:51:02
[2018-03-15 08:20:24]
HI
I'm sorry, im still confused? please could you send me screen shots of correct settings. that would be a great help.
My account is now through AMP rather than SC
Thanks,
Ollie
[2018-03-15 18:17:54]
We need you to login to this Support Board with the Sierra Chart account that you are using. You can do that with Help >> Support Board. Do that and just post here and say you logged in again.
[2018-03-16 08:11:10]
User339776 - Posts: 22
Hi, this is the account with AMP.
While im here, i don't seem to have right session settings for ES cash session. could you please send me correct settings for ES as well.
Many thanks
[2018-03-16 08:25:03]
OK we see you are using Rithmic. So what we want you to do is to follow the instructions here to update the Symbol Settings:
Global Symbol Settings: Update Symbol Settings
After that follow the instructions here to apply them to the CL futures contract chart:
Global Symbol Settings: Update/Apply Symbol Settings to Charts
This second step above can also be used for the ES futures.
Date Time Of Last Edit: 2018-03-16 08:25:18
[2018-03-16 09:54:51]
Great, Thanks. working
lastly, can you tell me in the 'number bars, calculated values' study which setting i need for delta change from last bar
[2018-03-16 19:46:20]
John - SC Support - Posts: 37327
I believe you are looking for the Ask Volume & Bid Volume Difference Change (AskV - BidV BarDiff). On the Subgraphs tab of the Numbers Bars Calculated Values study, find the Subgraph. Select this item and then change the Draw Style to Visible.
You can find the documentation for this study here, which also lists all the subgraphs and what they represent:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
Date Time Of Last Edit: 2018-03-16 20:00:42
[2018-03-16 19:59:50]
An update has been made to the prior post. We think you are looking for:
Ask Volume & Bid Volume Difference Change (AskV - BidV BarDiff):
Date Time Of Last Edit: 2018-03-16 20:02:33
