Date/Time: Sun, 19 Jan 2025 00:17:24 +0000
How to tell if an order is a simulated order?
View Count: 681
[2018-03-12 08:41:23] |
User79074 - Posts: 105 |
For example s_SCTradeOrder od; sc.GetOrderByOrderID(500, od) Is there something like this od.isSimulatedOrder()? Or another way to determine that the order is simulated? |
[2018-03-12 19:10:18] |
You can indirectly tell and this is explained here: http://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#GetOrderByOrderID But we will add a flag variable indicating this to the order structure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-13 08:27:58] |
I'm not able to piece it together, can you provide an example?
[2018-03-13 18:49:39] |
Update to the current version of Sierra Chart: Software Download: Fast Update There is now this new structure member to determine this: Automated Trading From an Advanced Custom Study: [Type: int] IsSimulated Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
