Date/Time: Sun, 19 Jan 2025 00:26:34 +0000
Can I get market depth for US equities?
View Count: 1854
[2018-03-12 05:54:06]
User133505 - Posts: 2
If I can't get market depth for stocks directly from SC, can i sign up for some service that will connect to SC for market depth for stocks?
my 2nd question is:
i Have a TDameritrade accnt. if i connect it to SC, what fees am i saving?...(just the exchange realtime quote fees since i'll be getting realtime quotes from TD, right?)
thanks
[2018-03-12 19:06:09]
Yes through Interactive Brokers you can:
http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#AccessingLevel2_MarketDepthDataForStocks
You might be able to get market depth data though for NYSE stocks through TD Ameritrade. You can try:
http://www.sierrachart.com/index.php?page=doc/AmeriTrade.php
Refer to:
http://www.sierrachart.com/index.php?page=doc/FileMenu.html#OpenMarketDepthWindow
Yes.
Date Time Of Last Edit: 2018-03-12 19:06:55
[2018-03-12 22:04:31]
Hi i tried connecting SC to my tdameritrade accnt and the SC message log showed the following:
"getting streamer information: step 2 of 3"
"server error while trying to get the streamer info. Error: ns error msg. User is not allowed to access streamer."
so should i have to contacted TDameritrade first to let them know i'm trying to connect thru SC so they can activate "streamer"?
what is a streamer?
i can log into thinkorswim platform and display realtime charts w/o any issue so i dont know why i dont have access to 'streamer'
please help.
thanks
[2018-03-13 00:17:50]
Yes you do need to contact TD Ameritrade about this error:
"User is not allowed to access streamer."
They should know what the term streamer means. It simply is referring to the API streaming real-time data.
Date Time Of Last Edit: 2018-03-13 00:18:09
