Date/Time: Sun, 19 Jan 2025 00:22:46 +0000
Automatic distribution of an attached chartbook to some of the allowed users only
View Count: 597
[2018-03-11 19:51:40] |
Zosimus - Posts: 345 |
Is it possible to automatically distribute a chartbook that is attached to a dll only to some of the users that are authorized to use the dll?
[2018-03-11 20:59:39] |
No. You will need to send it to them: File Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
