Date/Time: Sun, 19 Jan 2025 03:03:50 +0000
Tick Charts Oscillators??
View Count: 889
[2018-03-11 19:42:46] |
User509820 - Posts: 69 |
Why do the studies calculate change depending on how many days are loaded for tick charts? How can these be accurate?
Date Time Of Last Edit: 2018-03-12 02:56:51
[2018-03-12 02:58:17] |
We are not going to answer this question for obvious reasons. There are no specifics here. We do not know what study you are referring to, we do not know the Input settings of that study, we do not know what the underlying data is. Also the analysis of this is chargeable at 150 USD per hour based on available time. So in other words, it is your responsibility to look at the documentation for the study, look at the underlying data, and if you feel there is something wrong tell us what is wrong. If there is a problem we will certainly resolve it. The studies are 100% accurate as they are designed and documented and we are spending a lot of money, documenting by my mathematical formulas each and every single study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-12 02:59:18
[2018-03-12 03:26:31] |
I use tick charts (number of trades). What I am referring too is when using studies like RSI or CCI the studies will change value depending on number of days loaded. What is the correct way for the settings to be accurate? Thanks!
[2018-03-12 04:30:09] |
For the RSI, what is the Average Type input set to? What are the Length Inputs set to? How many bars in the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-12 04:31:37
[2018-03-16 01:06:15] |
The average type, inputs, number of bars does not matter I have tried multiples variables. Is that just how tick charts work? Depending on how many days are loaded the indicators will calculate differently? I don't have this issue with timed charts, it doesn't matter how many does are loaded the studies will always calculate the same.
[2018-03-16 01:25:08] |
Make sure you have this option enabled: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) If it is not enabled, then that would lead to the inconsistency. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
