Date/Time: Sun, 19 Jan 2025 00:09:36 +0000
Color Bar Alert Condition Extension Line: Line Labels not drawing.
View Count: 1091
[2018-03-10 17:02:52] |
RonW - Posts: 105 |
This is a daily chart with one Color Bar by Alert Condition study. The Alert is H<L[1], which identifies a gap on the price chart. The subgraph Color Bar SG1 is set to Ignore. Draw Extension Lines is set to yes and I am getting the correct Extension Lines drawn. However, I have the Name Label and Value Label boxes checked for the Extension line and the labels are not drawing. Thanks for your help. http://www.sierrachart.com/image.php?Image=15207013331000.png |
[2018-03-10 19:49:52] |
Labels are not currently supported for those extension lines but we will add support for it in the next release.
