Date/Time: Sun, 19 Jan 2025 00:23:28 +0000
Triggered limit order cannot be adjusted by one tick
View Count: 801
[2018-03-10 00:06:50]
patrader - Posts: 92
I have the offset value set to one tick. After placing the order, try dragging it higher or lower by just one tick. It does not move. Only if you amend the triggered limit order by 2 ticks or more will it move. Can you see this error and fix?
[2018-03-12 05:54:47]
We will check on this and take care of it.
