Date/Time: Sat, 18 Jan 2025 23:56:45 +0000
Adjusting candlestick transparency
View Count: 1638
[2018-03-09 17:46:57] |
chili - Posts: 14 |
Is there a way to adjust the transparency of the main price graph candlesticks?
[2018-03-09 18:42:21] |
No there is not. They are not transparent. However, refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-10 00:27:49] |
JoseyWales - Posts: 67 |
Consider changing your graph draw type to Candlestick Bars Hollow from the chart settings page for a less prominent display.
