Date/Time: Sun, 19 Jan 2025 00:23:18 +0000
drawings missing
View Count: 1115
[2018-03-09 17:36:15] |
User163689 - Posts: 29 |
i have a chart where i have drawings but they are not showing on chart and not hidden, I have those same drawings copied onto other charts and they show up any clues why not on main chart? I can go to master chart and manage drawings and they show up in file and if i hide they disappear from copied charts
[2018-03-09 18:40:38] |
Make sure this option is disabled: Chart Menu: Hide Chart Drawings (Chart menu) There is also additional information about this kind of issue in that section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-09 18:41:19
