Date/Time: Sat, 18 Jan 2025 23:53:58 +0000
Cannot connect to Rithmic
View Count: 730
[2018-03-09 14:49:33]
SviCh - Posts: 40
I'm using Windows XP SP3, SierraChart 1708.
When I'm trying to connect to Rithmic I get the following
Rithmic Trading | Port for executable: 3822 | 2018-03-09 08:25:17
Listening socket (912). Port 3822 | Closed. | 2018-03-09 08:25:17
Rithmic Trading | Starting server: C:\SierraChart\SierraChartNewest\Rim\DTCBridge.exe | 2018-03-09 08:25:17
Error running C:\SierraChart\SierraChartNewest\Rim\DTCBridge.exe. Windows error code 193: %1 is not a valid Win32 application. | 2018-03-09 08:25:17 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-03-09 08:25:17
[2018-03-09 16:04:57]
Sierra Chart - Max - Posts: 5779
From the Rithmic Introduction section:
Rithmic Trading Platform Service: Introduction
The Rithmic trading platform service can only be used on Windows 7 and higher. Windows XP and Vista are not supported. It is also not recommended to use any other operating system other than Windows.
Sierra Chart Support
