Date/Time: Sun, 19 Jan 2025 00:12:37 +0000
Version 1713, Custom Study did not follow
View Count: 774
[2018-03-08 18:07:57]
lpfin123 - Posts: 59
Good afternoon,
I've just updated to the version 1713 (I believe I was on 1689 before). I had some custom study from a third party but they do not appear anymore. It's the first time that I make a version update and that these studies does not follow.
They cannot be found in "Add Custom Study" neither (In Chart Studies).
Is there a problem? Is there something I need to do on my side?
Thank you,
[2018-03-08 19:37:51]
Exit from Sierra Chart and then start it again using the icon on your desktop. And make sure you do not use the icon with _64 at the end of it.
