Date/Time: Sat, 18 Jan 2025 23:52:31 +0000
Connecting data and trading with two different data provider
View Count: 563
[2018-03-08 18:03:37] |
User114886 - Posts: 4 |
Hi, I want to know if it is possible to connect a transact account and have the data provided with my subscription to transact but have the trades go through my account on Interactive Brokers on the same sierra chart instance.
[2018-03-08 21:06:25] |
No this is not supported. You need to use the Sierra Chart Exchange Data Feed for this: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
