Date/Time: Sun, 19 Jan 2025 00:27:04 +0000
ESM18 SC Data feed for 3/7/18 is +1 handles from CME data
View Count: 1208
[2018-03-08 15:14:54] |
User796776 - Posts: 95 |
The ESM18 contract from the SC data feed is +1 handles above CME data. ftp://ftp.cmegroup.com/pub/settle/stleqt FINAL PRE-CLEARING PRICES AS OF 03/07/18 06:00 PM (CST) ES CME E-MINI S&P 500 FUTURES JUN18 Open 2708.00 High 2735.25 Low 2686.50 Last 2727.25 Settle 2728.25 |
[2018-03-08 16:24:19] |
This would be incredibly unlikely. Check to make sure you understand what contract month you are looking at in the chart. Refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-08 17:22:10] |
Not sure how I am misunderstanding, apologies if this is the case. I am using Continuous Futures Contract - Date Rule Rollover, Back Adjusted. My chart rolled from H to M today. SC reports "ESM18 [CB] [M] Daily #17 | Back adjust amount for symbol ESH18 is 6. | 2018-03-08 11:39:28 " I have executed a "Delete All Data And Download" but my data values seem to be incorrect. SC Historical Daily Chart Wed 2018-03-07 00:00:00.000 Bar Begin Time Region 1 ESM18 [CB] [M] Daily #17 () Price Chg: -0.75 Open: 2706.00 High: 2736.25 Low: 2687.25 Last: 2729.25 I also looked at Barchart data from 3/7/18 and it matches the CME data. S&P 500 E-Mini Jun '18 (ESM18) Open 2,708.00 High 2,735.25 Low 2,686.50 Last 2,728.25 Somehow my ESM18 historical chart is off from barchart and the cme. I am unsure how to proceed. |
[2018-03-08 19:41:01] |
This is not something we provide support for if you are using the back adjustment option. Do not use that particular Continuous Futures Contract option if you want accurate prices.
