Date/Time: Sun, 19 Jan 2025 00:16:52 +0000
bitmex
View Count: 1304
[2018-03-08 14:56:49] |
User473945 - Posts: 1 |
I can not connect to BITMEX I have followed the instructions in detail with a brand new computer and a solid recent router. I see this line... BitMEX WebSocket | Extension reserve bits set and not supported. | 2018-03-08 14:46:14 I will send a message log for analysis |
[2018-03-08 21:05:01] |
The real problem is not that particular line but this one: BitMEX WebSocket | Header line. HTTP/1.1 400 Bad Request | 2018-03-08 14:46:14 Why this is happening we do not know. You need to ask BitMEX about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-09 00:07:26] |
qq41378235 - Posts: 3 |
bitmex still can not be connected. I have been using sierrachart for a week to connect to bitmex. It suddenly could not connect to bitmex from UT 0:00 2018 March 09..
[2018-03-09 00:27:14] |
just found it is fine now..thanks !!
