Date/Time: Sun, 19 Jan 2025 00:20:32 +0000
[Programming Help] - Two Candle subgraph reference for Color Background based on Alert Condition question
View Count: 1309
[2018-03-08 14:25:27] |
User809700 - Posts: 14 |
Hello, I understand that help is not provided for formulas related to the Color Background Based on Alert condition, but perhaps someone in the community can throw me a hint. Thanks in advance. In a nutshell, i want an alert condition based on two candles. The first candle should check for id2.sg2>1, and the second(or current candle) should check for id3.sg.3>1. I am currently getting a syntax error which i believe is due to how i am referencing the previous candle. My formula is as follows: =AND(id3.sg3>1, id2.sg2>1[-1]) I have also tried the reverse: =AND(id2.sg2>1[-1], id3.sg3>1) Maybe you cannot reference a study subgraph for previous candles and must therefore use a spreadsheet alert study, if so, i would appreciate the hint. Thanks, :-) |
[2018-03-08 14:57:23] |
infpz - Posts: 826 |
=AND(id3.sg3>1, id2.sg2[-1]>1) Your [-1] on the second part of your 1st example is the wrong place I believe. |
[2018-03-08 17:50:49] |
Yep, that works . . . i really appreciate your response. Thanks you.
