Date/Time: Fri, 07 Feb 2025 14:40:33 +0000
Alert Condition: Current Day
View Count: 1295
[2018-03-08 14:16:42] |
User525997 - Posts: 20 |
Hello. Is there a way to create an alert condition e.g. for the "color bar based on alert condition" indicator which defines a bar as a bar of the current trading day? I tested the formular: =(BARDATE = DATE(Year,Month,Day)) which is working but needs adjustment every day. Thank You. |
[2018-03-08 22:42:50] |
You could use the NOW function to access the current date: https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#NOW_Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-22 16:36:39] |
whats1thingnow - Posts: 407 |
was looking for the same thing and found TODAY() this did the trick =BARDATE=TODAY() Date Time Of Last Edit: 2022-07-22 16:59:53
