Date/Time: Mon, 28 Sep 2026 03:07:02 +0000
[User Discussion] - Count number of long entries #CREF circular reference error
View Count: 1919
[2018-03-08 06:44:46]
User701453 - Posts: 176
Im trying to count the number of long entries, as I do not want to have more then two trades per valid signal. Until there is a short entry taken.
I am able to count the long entries using the P column and below code:
=IF(AND($K$3=1,$J$8=0),($P$3 + 1), IF( OR( $M$3,$H$35 <> 0), 0 ,IF(ISBLANK($P$3),0 ,$P$3)))
However I get a #CREF circular reference error when I try to reference the $P$3 value in the K3 Buy Entry cell.
=AND($J$8=0,ID38.SG1@3<>0,$P$3<2)
Any assistance is needed to get this to work correctly.
[2018-03-08 14:33:45]
Sawtooth - Posts: 4355
Try this:
P3:
=IF(OR(M3,$H$35<>0),0,IF(AND(K3,$J$8=0),P4+1,P4))
K3:
=AND($J$8=0,ID38.SG1@3<>0,P4<2)
In this situation:
-You don't need to use absolute references of Formula Column cells.
-You need to reference row 4 to avoid a #CREF error.
-The zeroing IF needs to precede the incrementing IF.
Date Time Of Last Edit: 2018-03-08 16:05:39
[2018-03-08 15:02:34]
Post#2 edited
[2018-03-08 15:39:33]
tomgilb
Thanks for your assistance .
I`m receiving a SYNTAX error with the P3 cell code.
=IF(OR(M3,$H$35<>0),0,IF(AND(K3,$J$8=0),P4+1),P4))
Date Time Of Last Edit: 2018-03-08 15:59:32
[2018-03-08 16:06:14]
Sorry, P3 should be this:
[2018-03-08 17:31:49]
Thanks tomgilb.
Works perfect.
I had been banging my head on solving this for over a week.
You did it in a few minutes.
Sierra support staff, please add tomgilb wisdom to the spreadsheet example page.
Spreadsheet Example Formulas and Usage
[2018-03-08 18:51:38]
Still getting a #CREF! error when referencing P4<2
K3:
Im using spreadsheets of SC version 1705.
Maybe that makes a difference with the #CREF! error issue.
Date Time Of Last Edit: 2018-03-08 18:52:12
[2018-03-08 19:41:52]
It was working, but now it's not?
It must be from something else.
Did you change the formula in P3?
[2018-03-09 02:40:50]
Its working was in regard to the syntax error in P3 being removed.
After running the following code in P3.
The code doesn't count the first trade entry, so i will try to figure out why.
I may just adjust the max limit number and move on to the next task.
I did a full reboot and the #CREF! error issue hasn't shown back up yet.
So hopefully it wont.
Thanks again for all your assistance.
Much appreciated.
Date Time Of Last Edit: 2018-03-09 11:19:36
