Date/Time: Sun, 24 Nov 2024 06:34:56 +0000
non.NET - #SYNTAX! error using MAX function
View Count: 1506
[2013-10-01 13:49:22]
namlem - Posts: 94
please notice, that in non.NET Spreadsheet System Alert study, when you use new reference addresses, MAX function returns #SYNTAX! error. v1029
=MAX(ID1.SG1.3:ID1.SG1.10)
Also another minor bug - Fix Column functionality doesn't work in Spreadsheets.
[2013-10-01 23:16:57]
We will look into this.
Fix Column may not be supported at this time.
[2013-10-07 18:44:19]
namlem - Posts: 94
FYI
in v1032 MAX() not fixed yet, additionally "=MIN(ID1.SG1.3:ID1.SG1.13)" - throws the same error.
[2013-10-08 00:50:47]
We are still working on this. Hopefully the solution to this should be released within the next three days.
