Date/Time: Sun, 19 Jan 2025 00:00:01 +0000
message log
View Count: 640
[2018-03-06 17:39:46] |
PATRICIA - Posts: 10 |
I am getting a lot of exceptions in my message log for drawings on everychart and I have no idea what it means. Also got a pop up window with "Encountered an improper argument" I have been having issues it seems with every update I have done in the last month or so. Message log pasted below. Please advise. Software version: 1705 | 2018-03-06 09:43:29 Enabled for: Advanced Features. | 2018-03-06 09:43:29 Enabled for: Advanced Features 2. | 2018-03-06 09:43:29 Enabled for: Sierra Chart Historical Data Service. | 2018-03-06 09:43:29 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-03-06 09:43:29 Current selected Data/Trading service: TransAct Trading | 2018-03-06 09:43:29 Chart Update Interval: 40 | 2018-03-06 09:43:29 Service username command line set: go*** | 2018-03-06 09:43:29 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-03-06 09:43:29 2018-03-06 09:43:29 Local computer time | 2018-03-06 09:43:29 2018-03-06 14:43:29 Local computer time in UTC | 2018-03-06 09:43:29 2018-03-06 09:43:29 Local computer time in SC Time Zone | 2018-03-06 09:43:29 2018-03-06 10:27:09 Server time in UTC | 2018-03-06 09:43:29 Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-03-06 09:43:29 Program path: C:\SierraChart\SierraChartTransActMA\ | 2018-03-06 09:43:29 Data Files path: C:\SierraChart\SierraChartTransActMA\Data\ | 2018-03-06 09:43:29 OS Version Number: 10.0 | 2018-03-06 09:43:29 Locale Setting: C | 2018-03-06 09:43:29 (Message log content removed) 2018-03-06 11:38:14 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:15 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:16 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:18 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:20 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:21 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:22 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:24 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:25 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:26 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:27 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:29 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:30 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:31 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:33 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:34 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:35 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:37 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:38 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:39 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:41 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:42 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:43 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:45 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:46 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:47 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:49 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:50 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:51 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:53 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:54 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:55 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:57 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:58 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:38:59 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:39:01 NQH8 1.25 Range #4 | Exception in c_Chart::ChartDraw. Section 7. | 2018-03-06 11:39:02 NQH8 1.25 Date Time Of Last Edit: 2018-03-06 18:14:48
[2018-03-06 18:14:07] |
Disregard our prior answers. We will try to narrow the problem down and see what is causing it and see if we can resolve it but it is a Windows 10 issue on the side of Microsoft.
