Date/Time: Sun, 19 Jan 2025 00:14:54 +0000
APPLYING TEMPLATES INCONSITENT ACROSS DIFFERENT CHARTBOOKS
View Count: 1076
[2018-03-06 16:52:31]
User725605 - Posts: 60
I have several Chartbooks setup.
I have a saved and named template for these.
I made some changes to the layout of these charts by going to the CHART STUDIES Page and removing or adding studies to a new preferred chart layout.
I saved and named these changes as a NEW TEMPLATE with a different name.
When I went to apply this NEW template on a chart and throughout a complete charbook for the first time, it applied with no issues.
When I attempted to do the same on another Chartbook it would NOT apply the new template.
I tried on several other Chartbooks and one of them worked but the rest did not. This is very confusing. I checked all of my chart settings and they are
the same... unless I have missed something that would be causing this issue that I would appreciate you directing me to.
If I create a brand new chart the template will apply.
This begs the question - Once a chart is created and you wish to apply a different template will this not work?
Please advise.
Thank you
[2018-03-07 21:33:26]
The way to analyze this is just look at one particular chart and study.
After you apply a Study Collection to a chart you can see the studies you put on the chart through Analysis >> Studies. They should be there. Confirm that.
If they are not displaying anything, then check the Input settings for those studies to make sure they are as intended and make sure there is sufficient data loaded in the chart. Here are more details:
Chart Studies: Resolving Study Not Visible Issue
