Date/Time: Sun, 19 Jan 2025 00:27:41 +0000
Study compressing size of chart
View Count: 665
[2018-03-06 16:43:08] |
User747654 - Posts: 39 |
I am using the Initial Balance Levels study for trading ES. When I load the study it forces the chart to show all the levels including the extreme levels which is making the chart compress. Is there a way to not force the chart to show the levels that would not normally be visible on the chart? Thanks |
[2018-03-07 14:49:09] |
John - SC Support - Posts: 37327 |
Refer to the documentation here to fix this problem: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
