Date/Time: Sun, 19 Jan 2025 00:27:30 +0000
[User Discussion] - HIGHESTHIGH AND LOWESTLOW
View Count: 802
[2018-03-06 13:48:35] |
User82615 - Posts: 106 |
HELLO I'M STARTING TO LEARN TO PROGRAM STUDIES AND SYTEMS USING ACSIL , AND WHILE LEARNING HOW TO USE THE FUNCTION HIGHESTHIGH AND LOWESTLOW, I COPIED IT AS IT IS IN THE EXAMPLES STUDIES THAT THERE ARE IN THE MANUAL , BUT I WAS WONDERING IF IT WOULD BE POSSIBLE TO CALCULATE THE HIGHESTHIGH OR THE LOWESTLOW OF AN INDICATOR AS FOR EXAMPLE AN STOCHASTIC. IF IT IS POSSIBLE COULD YOU PLEASE GIVE ME A HINT OR THE STEPS OF HOW TO DO IT ?, BECAUSE I'M DRIVING MYSELF CRAZY TRYING TO DO IT. THANK YOU VERY MUCH IN ADVANCE FOR YOUR HELP |
[2018-03-06 19:03:15] |
Samir - Posts: 4 |
SCSubgraphRef Stochastic = sc.Subgraph[0]; SCSubgraphRef StochasticHigh = sc.Subgraph[1]; sc.Stochastic(sc.BaseDataIn, Stochastic, 10, 3, 3, MOVAVGTYPE_SIMPLE); sc.Highest(Stochastic, StochasticHigh, 20); float StochasticHighVal = StochasticHigh[sc.Index]; I guess something like this should work. |
