Date/Time: Sun, 24 Nov 2024 06:08:53 +0000
Chartbook Stucks Sierra
View Count: 1282
[2013-10-01 08:59:11] |
Ronin - Posts: 35 |
Hi, I'm experiencing a lot of freezes (sierra not responding) issues lately I noticed that it happens when opening/saving/using specific chartbook that I have This chartbook contains only historical charts (with maximum number of days to load - 3000) while it had intraday charts mostly before I change it to the current type - the problem started only with the current type (historical only) Before these freezes I've never had issues like this with sierra (the "worst" performance was very high cpu when loading "heavy" intraday charts What do u think it might be? and how can I check for an error log after I "end task" sierra to shut it down thank you |
[2013-10-01 09:02:42] |
Refer to help topic 30 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
