Date/Time: Sun, 19 Jan 2025 00:09:16 +0000
Tool to drawn composite profile for TPO
View Count: 1995
[2018-03-06 07:37:38] |
NumbersBars - Posts: 141 |
Hi, Is there anyway/tool which similar to "Drawn volume profile" that I can use to draw custom composite TPO profile? Currently I am using "Merge with Prior/Next Profile" function in TPO chart, which can only merge profile one by one, it is very time consuming and inefficient way to create a composite TPO profile. I am looking for a tool that I can highlight the range, and create composite TPO profile. So, Just wondering if there's any existing Sierra function/tool that I am missing out? |
[2018-03-06 21:50:20] |
You can effectively do the same thing with this particular Input: Time Price Opportunity (TPO) Profile Charts: Number of TPO Profile Periods Set it to: From Start Date-Time to End Date-Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-07 02:58:53] |
By using the method recommeded above, 1 composite(multiple-period) TPO profile is created, however, there will be only 1 TPO profile on the chart. Is there anyway I can have both multiple-period TPO profile and single period TPO profile displayed on the same chart? (The exact same function as Drawn Volume Profile as mentioned in post #1). I tried to add second "TPO Profile Chart study" into same chart, nothing is displyed. May I know how many "TPO Profile Chart" study is allowed to be added into 1 chart? I have attached a screenshot of TPO chart I created using manual profile merging to show you the result I'm trying to achieve. Thanks. |
Private File |
[2018-03-07 03:38:18] |
There can only be one TPO Profile Chart study on a chart. What we can do is add a new merge command to allow specifying a custom Date-Time range. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-03-07 04:02:36] |
We thought of a good way to perform a TPO profile merge across a Date-Time range, by specifying through a right-click shortcut menu command both the beginning and ending of the range. We will implement that.
