Date/Time: Sun, 19 Jan 2025 00:04:15 +0000
Spreadsheet - Formula Rows extending beyond data
View Count: 757
[2018-03-05 22:28:51] |
knoxville1915 - Posts: 38 |
I keep running into this issue of my formula columns extending beyond the available data in a spreadsheet study. This occurs when I change symbols and there are fewer bars in the data file than there were previously. I've attached a screenshot to illustrate the issue. Is there a way for the spreadsheet formulas to calculate only for the available data? Alternatively, is there a way to ensure that all new symbols loaded into the chart, even if they have a stored data file, are loaded with the same time scope as was previously set in the chart settings? |
screenshot1.png / V - Attached On 2018-03-05 22:27:57 UTC - Size: 37.76 KB - 263 views Attachment Deleted. |
[2018-03-06 03:45:35] |
We will see if it is practical to clear the formulas that go beyond the Number of Rows setting.
