Date/Time: Sun, 19 Jan 2025 03:07:44 +0000
[Programming Help] - 64bit custom studies compiled in Visual Studio
View Count: 1817
[2018-03-05 19:25:11] |
dtl-saw - Posts: 79 |
What is required to compile 64bit custom studies inside of Visual studio? Do I need to change any of my configurations as I have them set now for the 32bit compile. I've set my Visual studio environment exactly as you describe on your website here https://www.sierrachart.com/index.php?page=doc/UsingVisualCPlusPlus.php So, do I need to make changes from what you've described in this link and if so please provide what parameters need changing. Thanks |
[2018-03-17 00:17:29] |
Can someone from SC comment on this?
[2018-03-17 12:00:00] |
You need to create 64-bit solution and project configurations but that is not within the scope of our support. We also will not be updating the Visual C++ documentation either. We have had it with Microsoft and their trash Visual C++ crap and their deranged mentality. However, in the latest 64 bit version of Sierra Chart, you can use the Visual C++ >> Build command in Analysis >> Build Custom Studies DLL to make a 64 bit DLL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-17 12:15:17
[2018-03-18 04:59:17] |
WarriorTrader - Posts: 245 |
Being a UNIX guy back in the day, I agree with you. But unless you are going to move to LINUX one wonders how you will get rid of Microsoft. They are here to stay and a lot of us use Visual Studio. Good Trading, WT |
[2018-03-18 06:25:24] |
It is a gradual process but we will make it. Also, when using the Remote Build function, within Sierra Chart, the source code is compiled using GCC on a Linux server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
