Date/Time: Mon, 27 Jan 2025 19:13:52 +0000
Alert on execution
View Count: 926
[2018-03-05 17:20:51] |
User170575 - Posts: 221 |
Hi---what is the easiest way to have an alert go off on an execution on an order? Many thx, Cj |
[2018-03-05 17:55:12] |
There are three different Order Fill Alert settings that you can set for this. Refer to: Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-08 02:26:53] |
User873570 - Posts: 27 |
Hi, If I have a multi-lot order, and if it all gets filled at once, is it possible to get the alert to play just once? Thank you |
[2019-03-08 03:51:20] |
There will be multiple alerts because there are individual fills occurring.
