Date/Time: Sat, 18 Jan 2025 19:23:55 +0000
A replay of the operations I have done today
View Count: 854
[2018-03-05 15:36:22] |
User25311 - Posts: 32 |
Hello. Is it possible to make a replay of a chart and have my operations appear? In other words, I would like, at the end of the day, to be able to have a replay of the operations I have done on that day. Thank you. |
[2018-03-05 18:06:39] |
Yes chart replay is fully supported. Refer to: Replaying Charts However, replay is not going to show any non-simulated order fills. To display those, refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart So it is not possible to do a replay and then see the non-simulated trading during the replay. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-03-05 18:06:55
[2018-03-05 18:26:44] |
The functionality I was referring to was about non-simulated operations, but thanks anyway. I hope one day SC can do it.
