Date/Time: Sun, 24 Nov 2024 05:34:56 +0000
Data Issues
View Count: 1357
[2013-09-30 19:48:06] |
User39772 - Posts: 311 |
I have 2 instances running of SC both latest version 1029. Instance 1 is connected to IQFeed. Instance 2 is connected to my broker. Charts on Instance 2 are marked with [R] ie I receive data from 1st Instance for charts. Since I updated Instance 1 to latest version I see "Recon Wait" on Instance 2 and receive no data. Before I updated Instance 1 I saw delays in data update ie price in chart and T&S had a delay against the real price on the exchange. What can I do ? |
[2013-09-30 20:25:44] |
Post the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
